Page 1 of 2
hdf5.dll
Posted: Fri Nov 12, 2021 9:35 pm
by miguelvega
I'm starting to use the free version of STKO and when I tried to run an example which was done in one webinar I got these messages. What can I do in order to fix this issue?
Re: hdf5.dll
Posted: Sun Nov 14, 2021 11:15 am
by marafini.f
What version of OpenSees are you using?
Re: hdf5.dll
Posted: Sun Nov 14, 2021 1:18 pm
by miguelvega
I have downloaded both the official version from the web page and also the compiled version from Prof. Nicola's web page, which is recommended in the installation process of STKO.
Re: hdf5.dll
Posted: Mon Nov 15, 2021 9:19 am
If you downloaded the version from prof. Tarque's website you should have an hdf5 folder in C:\OpenSees-Solvers.
Can you confirm that?
Immagine 2021-11-15 101610.png (20.49 KiB) Viewed 3917 times
If you installed everything correctly, and the STKO Kits looks like this, you should have no issue:
Immagine 2021-11-15 101742.png (25.71 KiB) Viewed 3917 times
Make sure the kits are correctly using the .bat file and you selected the correct solver in the analsys tab
Re: hdf5.dll
Posted: Mon Nov 15, 2021 6:49 pm
by miguelvega
Great! I did all you said and the message didn't appear again. Thank you very much. Now I got the "WARNING No Analysis type has been specified" message, but I think I just have to follow every step from the webinar video on youtube. Thanks again!
Re: hdf5.dll
Posted: Tue Nov 16, 2021 8:29 am
Yes, probably there is some step missing.
Also, what webinar are you referring to?
Re: hdf5.dll
Posted: Tue Nov 16, 2021 12:27 pm
by miguelvega
This webinar https://www.youtube.com/watch?v=vPB9ZwTZbNw&t=985s
Sir, now I'm trying to do the test material and I get this error message, could you please help me with this issue? Is it related that I'm using the free version?
Re: hdf5.dll
Posted: Tue Nov 16, 2021 2:36 pm
It was just a file missing in the initial uplodad of the 2.0.5 version.
Re-Download it and re-install it. It will be solved.
Regarding your error:
It was a very old webinar. At that time, the STKO analysis command did not have the "Adaptive Time Step" automation. So I tried to use a custom Tcl script to emulate that functionality. However, that script is incompatible with the new version. (If you want to make it work, you have to un-check the wipeAnalysis option of the previous analysis)
Don't worry anyway! in the new version we have a built-in Adaptive time step that makes the custom Tcl procedure useless:
Here's the modified file, I also added the monitor, a new feature that allows you to monitor the response of a point in real-time.
fiber_column.zip
(157.42 KiB) Downloaded 220 times
Immagine 2021-11-16 152920.png (59.35 KiB) Viewed 3894 times
Re: hdf5.dll
Posted: Tue Nov 23, 2021 7:44 pm
by begumemte1991
Hello team STKO!
I am getting the following error while running an analysis.
I'm receiving this error despite having the hdf5 folder in the OpenSees solver folder.
Re: hdf5.dll
Posted: Wed Nov 24, 2021 2:19 pm
by begumemte1991
I request you to reply to my query.
