Page 1 of 2
soil material stress-strain result
Posted: Fri Mar 26, 2021 2:15 pm
by begumemte1991
I have analysed a soil-pile system where I want to read the material stresses and strain of the soil elements. In Opensees if we set the recorders (for eg. "recorder Element -file Gstress1.out -time -eleRange 1 $nElemT material 1 stress") we can extract the data very easily and then for a particular element we can read the stresses and strain. But I am finding it difficult to extract the results in STKO postprocessor. No doubt we can view the contours of stresses and strains for the whole geometry, but getting the data in each and every element is difficult.
I have even tried to manually extract the data through the "custom command" option, but in the .out file nothing was there except the time column.
Also, if I want the displacement (or bending moment) at each node (or element) of the pile, it is very difficult to extract it because the pile is hiding inside the soil. Selecting each node becomes very difficult and tedious.
I hope there are some other alternatives to this. Please shed some light in to it. Thank you.
Re: soil material stress-strain result
Posted: Fri Mar 26, 2021 5:09 pm
Probably you wrote it wrong. Can you share your script?
And what element are you using?
If you want to select something that is hiding, you can hide the surrounding geometries with the Hide/Show command.
Furthermore, starting from STKO version 2.0.0, we can use automation using the Python API.
Have a look at the latest webinar about the Python API in the STKO post processor. We explain exactly that: how to extract data programmatically from the STKO post processor
Posted: Fri Mar 26, 2021 6:36 pm
by begumemte1991
Thank you for your quick reply.
I have shared the .scd file herewith.
I am using SSPbrick for soil model.
I wrote it wrong. Definitely the soil can be hidden by the show/hide command but my pile is modelled with a beam-column element and it is a hollow circular section. So, I can't click the inside nodes (I hope you can understand what I meant to say, it will be clear once you run my file). I don't know if there is some other way to do it.
Surely, I will watch the video. But for non python users like me lets see how it turns out. :) Thank you.
Posted: Mon Mar 29, 2021 4:51 pm
Your custom element recorder commands do not work because you are running the OpenSeesMP (parallel) version. It is quite difficult to write correctly those recorders for the OpenSeesMP. Because the model is partiitoned, so you would need to write 1 recorder for each partition, including only nodes/elements on that partition. I gave an explanation in the latest webinar explaining a similar issue with the Drift recorder in OpenSeesSP
I am using SSPbrick for the soil model.
You correctly asked for "stress" and "strain" (and not "material.stress" and "material.strain") in the MPCO Recorder, because the SSPbrick element has only 1 gauss point, and it does not accept the "material" keyword. In fact those results are visible in the STKO post processor.
You need to isolate the beam elements with the hide/show command. Then, to hide the beam-section extrusion, just un-check that option. You can also check the option to visualize the nodes, so it will be easier for selection
Posted: Sat Apr 03, 2021 2:18 pm
by begumemte1991
Ok got it! Thank you.
Can you please mention which webinar as there are a number of recent webinars. I tried to watch a few of them but could not find it.
Posted: Tue Apr 06, 2021 3:51 am
by begumemte1991
Dear team STKO,
Please mention the title of the webinar.
Posted: Tue Apr 06, 2021 7:35 am
by Clarabella
Dear Begumemte,
this is the link:
https://www.youtube.com/watch?v=TrHhvJ8L9ao
Reagards
Posted: Tue Apr 06, 2021 8:51 am
by begumemte1991
Thanks a lot!
Posted: Sat Apr 10, 2021 11:00 am
by Horace Horsecollar
You are welcome!
Posted: Fri Apr 23, 2021 11:14 am
by begumemte1991
Hello team STKO,
Your custom element recorder commands do not work because you are running the OpenSeesMP (parallel) version. It is quite difficult to write correctly those recorders for the OpenSeesMP. Because the model is partitioned, so you would need to write 1 recorder for each partition, including only nodes/elements on that partition.
If possible can you please write and post a python script for extracting the output data (for example, nodal displacements) manually with custom command when running with the OpenSeesMP?
