Extraction of results
Zeeshanbhat
Post by Zeeshanbhat » Wed Mar 24, 2021 12:48 pm
Dear Team,
There is something wrong in my postprocessor. when I extract the displacement of my node, it shows empty file as shown in attached figure. Even I tried to extract the results on my previous models which were running properly, it is showing empty file in those models also. Any help will be appreciated.
Re: Extraction of results
Post by STKO Team » Wed Mar 24, 2021 1:11 pm
It should work as before, probably there is something wrong with how you selected the node and/or the analysis stage.
Check the chartData, can you see results in their tables?
Could you please post some images showing how you perform the extraction?
