No Output
emrah13
No Output
Post by emrah13 » Sat Feb 20, 2021 6:16 am
I was working on one of the examples provided on your website. I uploaded an example problem and try to run it. Unfortunately, after running the analysis, I did not get any output. There was no error shown in the terminal.
Please help me to understand the reason and provide me the solution for it.
Thanks in Advance.
Re: No Output
Post by STKO Team » Sat Feb 20, 2021 9:38 am
We need to see your SCD file to understand what's going on.
Make sure you have the MPCORecorder.
emrah13
Re: No Output
Post by emrah13 » Sat Feb 20, 2021 10:39 am
I am trying to run the analysis for "dist_generic_uniaxial.scd" which I obtained from the website. Please see the link below.
Thanks.
https://drive.google.com/file/d/1saX6pc ... sp=sharing
Re: No Output
Post by marafini.f » Mon Feb 22, 2021 2:02 pm
Dear emrah13,
I downloaded the file you referenced from the site as I didn't have access to the drive link you shared. It does run correctly without requiring any modifications. Why do you say you cannot obtain results? Did you manage to load the database in the postprocessor interface?
Let us know which is the problem exactly.
For the future, we kindly ask you to upload your models in a zip file, it makes it easier for us to access them.
Enjoy your modeling.
emrah13
Re: No Output
Post by emrah13 » Mon Feb 22, 2021 3:47 pm
I cannot obtain any results basically I am not seeing opensees running in the command screen.
In the terminal, I got this message.
Running ""C:/Users/Emrah/Desktop/STKO STUDIES/OpenSees.exe" "" & pause" in "C:/Users/Emrah/Desktop/STKO STUDIES"
Is it because of the OPENSEES (3.2.2x64) version I have or am I missing something else?
Re: No Output
Post by STKO Team » Mon Feb 22, 2021 5:51 pm
That is the only message you have on the STKO terminal.
Then the OpenSees messages will be written in the OpenSees's console.
emrah13
Re: No Output
Post by emrah13 » Mon Feb 22, 2021 6:46 pm
I figured out the problem, I was trying to use opensees version I downloaded from the Opensees website. Using OpenSees 3.2.2 compiled by prof. Nicola Tarque solved the issue. Sorry for the inconvenience.
Thanks.
Re: No Output
Post by STKO Team » Tue Feb 23, 2021 9:29 am
Ok, so it means that the error was due to the fact that your OpenSees was not able to find the HDF5 DLL (libraries), that are required by the MPCORecorder.
The opensees compiled by prof. Tarque is working only because it includes a way to tell the operating system where tot find those libraries.
If in the future you need, for some reason, to use onother version of OpenSees that do not include the HDF5 libraries, you can copy the hdf5.dll, szip.dll and zlib.dll libraries from the STKO installation directory, to the directory where you have your OpenSees.exe
