'NoneType' Object
Posted: Fri Oct 30, 2020 6:45 pm
by Telec
i cannot write the input files for this error. why? thx
Re: 'NoneType' Object
Posted: Fri Oct 30, 2020 7:12 pm
by vokumus
I think you have object(s) that there is no element property assigned.
Posted: Fri Oct 30, 2020 7:22 pm
by Telec
by objects do you mean geometric elements?
Posted: Fri Oct 30, 2020 9:42 pm
by vokumus
Yes I mean objects. But interactions may need element property too. For example if you use a zero length interaction you have to assign a zero length element to it.
Posted: Mon Nov 02, 2020 9:33 am
Exactly as vokumus said, there is some Physical or Element property missing.
Make sure everything is properly assigned. If you cannot solve it, attach here your SCD file (zipped)
Posted: Mon Nov 02, 2020 5:05 pm
by Telec
OK thanks. I solved. In the model I had a plate divided into two parts. Each part corresponded to a different section (layered shell). Probably I had assigned the two sections to the two different faces. In this way the central edge was left unassigned.
I solved it by assigning a section to the entire plate and then later I only changed a faces.
