'NoneType' Object
Telec
'NoneType' Object
Post by Telec » Fri Oct 30, 2020 6:45 pm
i cannot write the input files for this error. why? thx
vokumus
Re: 'NoneType' Object
Post by vokumus » Fri Oct 30, 2020 7:12 pm
I think you have object(s) that there is no element property assigned.
Vefa OKUMUS
MSc. Structural Engineer
PhD candidate.
Software Developer.
Istanbul - Turkey
Telec
Post by Telec » Fri Oct 30, 2020 7:22 pm
by objects do you mean geometric elements?
vokumus
Post by vokumus » Fri Oct 30, 2020 9:42 pm
Yes I mean objects. But interactions may need element property too. For example if you use a zero length interaction you have to assign a zero length element to it.
Vefa OKUMUS
PhD candidate.
Software Developer.
Istanbul - Turkey
Post by STKO Team » Mon Nov 02, 2020 9:33 am
Exactly as vokumus said, there is some Physical or Element property missing.
Make sure everything is properly assigned. If you cannot solve it, attach here your SCD file (zipped)
Telec
Post by Telec » Mon Nov 02, 2020 5:05 pm
OK thanks. I solved. In the model I had a plate divided into two parts. Each part corresponded to a different section (layered shell). Probably I had assigned the two sections to the two different faces. In this way the central edge was left unassigned.
I solved it by assigning a section to the entire plate and then later I only changed a faces.
