BeamSectionproperty
nisaralikhan
BeamSectionproperty
Post by nisaralikhan » Fri Sep 25, 2020 10:32 am
I face an issue when I define beamsection physical property. The following error appears when I define beamsection property
"TraceBack:
File "C:/Program Files/STKO\external_solvers\opensees\physical_properties\special_purpose\BeamSectionProperty.py", line 1146, in makeExtrusionBeamDataCompoundInfo
info.add(info_item.property, 1.0, True, False, info_item.yOffset, info_item.zOffset)"
Attached please find the STKO file.
Would you please help me to solve the issue.
Thanking you.
Bare Frame.rar
(43.53 KiB) Downloaded 167 times
Re: BeamSectionproperty
Post by STKO Team » Fri Sep 25, 2020 10:50 am
Dear User,
That error appears only when you first create the beamSectionProperty, because by default the seciton is None (i.e. not chosen). And of course it cannot create the 3D visual extrusion. As soon as you select the fiber section that error will not appear anymore.
