Error using MPCO
Posted: Sun Jun 14, 2020 2:46 am
Hi, there,
I have just installed STKO and tried to do the pushover with the MPCO command. And the OpenSEES I used is Version 3.2.0 64-Bit.
At first, it showed the info in Fig. 1 to let me install the HDF5, so HDF 1.12.0 was installed. Then I run it again, the outcome in Fig. 2 was got, so could you tell me how to make it right? Thanks. P.S.: I just install the STKO, and then run the OpenSEES in another directory, don't know if it will affect the analysis.
