Dear all,
I was analyzing a 2D frame model with lumped zero length at beam and columns. Watching the tutorials I have realized that the rotation can be seen at Material Strain/S23 for each node. The moment can be seen at Material Stress/S23.
I would like to extract the results at each lumped hinge (zero length) moment vs curvature, is it possible? Becasue I would like to know which hinge goes under inelastic deformations and plot the constitutive law.
For example, If I have one story one bay frame, I will have 8 hinges for the 2 columns and 2 hinges for the beam, then I am expevted to plot 8 Moment vs Rotation results.
Thanks,
Nicola
PLot Moment vs rotation for lumped zero length
NicolaTarque
Re: PLot Moment vs rotation for lumped zero length
Dear Nicola,
First, let me explain how you should interpret the results of a zeroLength element:
A zero length element is a 2-node element with 1 integration point. So every time you want to visualize results on a zeroLength, use the GaussPlot.
The zeroLength element in OpenSees can have up to 6 materials in the 6 DOFs, but it is not mandatory that you set a material in every DOF. For example if you want to release one DOF, don't include it in the defintion of the ZeroLength Material property.
Now the results available for a zeroLength are:
That being said, If you ask for "material.stress" and you set a material only on 2 of the 6 DOFs for the zeroLength, then your output will have 2 components [sigma(1); sigma(2)]. If instead you set 6 DOFs, it will have 6 components, however since the name is "stress" STKO thinks it is a 3D stress tensor in Voigt notation, that's why you see [S11,S22,S33,S12,S23,S13 + all the invariants]. This is unfortunately something out of our control, and we are working on a solution to let STKO understand that material.stress with 6 components is not a stress tensor when computed on a zeroLength.
Now for your second question:
If you want to extract a chart of Moment-Rotation of all zeroLengths, do the following:
- material.stress
- material.strain
- material.somethingElse
- create a GaussPlot, so that you can select gauss points
- select all the gauss points of the zeroLength elements you want to extract Moment-Rotation from
- use the Extract Chart Data command
