Page 2 of 2
Re: Masonry example without fully postproces
Posted: Sun Nov 26, 2023 5:46 am
by Lei Lei
Thanks!
But why the data in the second file didn't contain the full-time history? It should have all the data during the 13400s instead of only the 450s.
Posted: Mon Nov 27, 2023 8:35 am
Sorry but I cannot test it, there is a tcl file for custom recorders that is not in the attachments
Posted: Tue Nov 28, 2023 2:05 am
by Lei Lei
Hello, you can just remove it.
It's just a 'recorder' file with code below:
set filename Results
file mkdir $filename
recorder Element -file $filename/ele-20-localforce.txt -time -ele 20 localForce;
recorder Node -file $filename/nodes-4-disp.txt -time -node 4 -dof 2 disp;
recorder Node -file $filename/nodes-5-force.txt -time -node 5 -dof 2 reaction;
Posted: Fri Feb 09, 2024 9:42 am
In my case it works fine.
However, since it's a parallel analysis with opensees mp, you need a parallel numberer and the mumps solver (see the attached file)
Curve Beam Model Test_Load Control.zip
(1.31 MiB) Downloaded 294 times
Posted: Sun Feb 25, 2024 1:15 pm
by Lei Lei
I get it!
Thanks for your reply!
Posted: Mon Mar 04, 2024 9:28 am
Posted: Sat Mar 09, 2024 2:07 pm
by Lei Lei
Dear STKOteam,
After using your recommended method for some time, I hope you can come up with a more convenient way to record node data.
Your proposed method creates only N files for N processes, and each file contains data for many nodes, making it difficult to find out which node the data belongs to.
Is there a way to output all of a node's data into a separate file under parallel computing?
Mon Nov 20, 2023 9:43 am
Otherwise, if you want to use plain recorders, you must create them one per process. Something like this:
recorder Node -file "ANodeRecorder_[getPID].txt" ....
where the [getPID] function will return the ID of the current processor.
So, in this way you will have N files, one for each process.
Then you can do some scripting to merge them
Posted: Tue Mar 12, 2024 10:45 am
Simple text-based node recorders are in OpenSees, STKO has no control over them.
Why don't you use the Monitor function in STKO? It's used to monitor a node response in real-time, but all it does is to write node data into a file, taking care of the processors.
Otherwise you can use the MPCORecorder and use the Python API to extract data from STKO post processor
