Coupled shear walls with diagonal reinforcement
farisuwais
Re: Coupled shear walls with diagonal reinforcement
Post by farisuwais » Sun Mar 03, 2024 10:02 am
hello team
thanks for the reply
now i am facing an error while trying to run the model "invalid type of element or number of nodes".
i attached the model for your kind review
Shell Element - P10.zip
(545.21 KiB) Downloaded 191 times
Post by STKO Team » Tue Mar 12, 2024 10:52 am
It's because your mesh is a mix of quadrilateral and triangular elements, but the ASDShellQ4 is only for quadrilateral elements.
Try to make your mesh all quad or all tria
farisuwais
Post by farisuwais » Mon Mar 18, 2024 12:24 pm
hi again
I have made significant progress in aligning the numerical results with experimental data. However, I have encountered convergence challenges, particularly around the 60% mark of the analysis.
Please take the time to review the model attached and provide me with following:
1. Clear instructions on how to have better matching between the numerical results and experimental results specially in the elastic range where you can notice that the base shear results are greater than the experiment
2. Guidance to reach 100% Convergence as It is stopping at 60% although I have increased the number of steps to 600 and using fine mesh
model.rar
(2.8 MiB) Downloaded 180 times
Post by kesavapraba » Mon Mar 18, 2024 12:32 pm
Hi, I want to look at the boundary conditions for the specimen to verify if that aspect is captured correctly in your numerical model. Can you please share the specimen setup?
farisuwais
Post by farisuwais » Mon Mar 18, 2024 12:38 pm
please clarify what is meant by specimen setup as i have attached the model
farisuwais
Post by farisuwais » Mon Mar 18, 2024 12:40 pm
i have added the other files as will to the RAR file
model.rar
(9.22 MiB) Downloaded 188 times
Post by kesavapraba » Mon Mar 18, 2024 1:49 pm
I understand that you have shared your numerical model, but I want to check the experimental setup to verify if the boundary conditions in numerical model is properly captured.
