try to run model of webinar_ssi_06_04_2020
Hello
i have some issue to run the model given with the webinar
i hve this error in terminal :
and also when i try to put it in post processing i just found mpco.data and no mpco file
Python Interface Initialization
(document-wise)
Initializing python interface of new document
Loading External Solver: OpenSees
AnalysesCommand - (static load control) conversion dt->duration = 1.0 (version 0 -> 1)
AnalysesCommand - (transient) conversion dt->duration = 0.0 (version 0 -> 1)
Command: Regenerate
Command: RunAnalysis
writing tcl input files in "C:/Users/medvi/OneDrive/Desktop/SKTO/exemples-webin/webinar_ssi_06_04_2020/single_processor"
creating main script: "C:/Users/medvi/OneDrive/Desktop/SKTO/exemples-webin/webinar_ssi_06_04_2020/single_processor\main.tcl" ...
creating NDM/NDF pairs for each node...
loop 1 finished in 2 iterations.
loop 2 finished in 1 iterations.
writing definitions...
writing materials...
writing physical_properties...
writing sections...
pre-process masses...
Found at least 1 user defined model subset.
writing nodes...
pre-processing elements...
pre-processing module: ASDAbsorbingBoundary2DAuto
pre-processing module: ASDAbsorbingBoundary3DAuto
pre-processing module: RCJointModel3DElement
writing elements...
writing analysis steps...
Running Time-Increment Utility...
writing analysis_steps...
write geometry...
write interactions...
write geometry...
Done.Input file correctly written!
End Command: RunAnalysis
Command: SetContext_PostProcessor
End Command: SetContext_PostProcessor
Command: OpenPostDocument
Serialization exception: Cannot open file: "C:/Users/medvi/OneDrive/Desktop/SKTO/exemples-webin/webinar_ssi_06_04_2020/single_processor/model_3d_init_stage_relax.mpco.cdata".
File: "..\..\MpcCore\MpcCoreApp\Serialization\MpcPostDocumentSerializer.cpp
Function: load (Line: 45)
error #0 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5F.c in H5Fopen(): line 793.
class: HDF5
major: File accessibility
minor: Unable to open file
error #1 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5VLcallback.c in H5VL_file_open(): line 3500.
class: HDF5
major: Virtual Object Layer
minor: Can't open object
error #2 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5VLcallback.c in H5VL__file_open(): line 3465.
class: HDF5
error #3 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5VLnative_file.c in H5VL__native_file_open(): line 100.
class: HDF5
error #4 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5Fint.c in H5F_open(): line 1707.
class: HDF5
minor: Read failed
error #5 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5Fsuper.c in H5F__super_read(): line 412.
class: HDF5
minor: Not an HDF5 file
An error occurred while loading the specified file. A default file will be created.
End Command: OpenPostDocument
AutoSave 2 (@ 1200000)
C:/Users/medvi/AppData/Local/ASDEA Software Technology/STKO\BackUp\model_3d_init_stage_relax-c4ee806d-798e-461d-b4d7-1928289d9e87.bak
File succesfully saved as "C:/Users/medvi/AppData/Local/ASDEA Software Technology/STKO\BackUp\model_3d_init_stage_relax-c4ee806d-798e-461d-b4d7-1928289d9e87.bak".
Command: SetContext_PreProcessor
End Command: SetContext_PreProcessor
Command: OpenPreDocument
File "C:/Users/medvi/OneDrive/Desktop/SKTO/documentation/Week2/ex3.scd" succesfully loaded.
End Command: OpenPreDocument
(document-wise)
Command: Regenerate
writing tcl input files in "C:/Users/medvi/OneDrive/Desktop/SKTO/documentation/Week2/MBR"
creating main script: "C:/Users/medvi/OneDrive/Desktop/SKTO/documentation/Week2/MBR\main.tcl" ...
writing sections...
No model subset found. The entire model will be written at the beginning.
writing nodes...
writing elements...
write geometry...
Serialization exception: Cannot open group: "FILE_INFO".
File: "..\..\MpcCore\MpcCoreApp\Serialization\MpcPostDocumentSerializerPrivate.cpp
Function: load (Line: 31)
error #0 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5G.c in H5Gopen2(): line 528.
class: HDF5
major: Symbol table
error #1 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5VLcallback.c in H5VL_group_open(): line 4186.
class: HDF5
error #2 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5VLcallback.c in H5VL__group_open(): line 4153.
class: HDF5
error #3 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5VLnative_group.c in H5VL__native_group_open(): line 125.
class: HDF5
major: Symbol table
error #4 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5Gint.c in H5G__open_name(): line 282.
class: HDF5
major: Symbol table
minor: Object not found
error #5 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5Gloc.c in H5G_loc_find(): line 462.
class: HDF5
major: Symbol table
error #6 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5Gtraverse.c in H5G_traverse(): line 855.
class: HDF5
major: Symbol table
error #7 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5Gtraverse.c in H5G__traverse_real(): line 630.
class: HDF5
major: Symbol table
minor: Callback failed
error #8 C:\autotest\hdf5112-StdRelease-dist-10vs14\build\hdfsrc\src\H5Gloc.c in H5G__loc_find_cb(): line 418.
class: HDF5
major: Symbol table
Command: OpenDatabase
Database "C:/Users/medvi/OneDrive/Desktop/SKTO/documentation/Week2/MBR/ex3.mpco" correctly open
End Command: OpenDatabase
Command: SurfaceColorMap
Command: NewPlotGroup
End Command: SurfaceColorMap
Command: EditAnalysisStep
Abort Command: EditAnalysisStep
AutoSave 3 (@ 1200000)
C:/Users/medvi/AppData/Local/ASDEA Software Technology/STKO\BackUp\ex3-ec75565e-92e2-4387-875a-5ec9058ee681.bak
File succesfully saved as "C:/Users/medvi/AppData/Local/ASDEA Software Technology/STKO\BackUp\ex3-ec75565e-92e2-4387-875a-5ec9058ee681.bak".
Database "C:/Users/medvi/OneDrive/Desktop/SKTO/documentation/Week2/MBR/ex3.mpco" correctly closed
(document-wise)
Command: Regenerate
Nothing to regenerate.
File "C:/Users/medvi/OneDrive/Desktop/SKTO/documentation/webinaires/webinar_ssi_06_04_2020/single_processor/model_3d_init_stage_relax.scd" succesfully loaded.
(document-wise)
Command: Regenerate
writing tcl input files in "C:/Users/medvi/OneDrive/Desktop/SKTO/documentation/webinaires/webinar_ssi_06_04_2020/single_processor/Nouveau dossier (2)"
creating main script: "C:/Users/medvi/OneDrive/Desktop/SKTO/documentation/webinaires/webinar_ssi_06_04_2020/single_processor/Nouveau dossier (2)\main.tcl" ...
writing sections...
writing nodes...
writing elements...
write geometry...
write geometry...
(document-wise)
Command: Regenerate
writing tcl input files in "C:/Users/medvi/Downloads/Wall_C2D_2 (1)"
creating main script: "C:/Users/medvi/Downloads/Wall_C2D_2 (1)\main.tcl" ...
writing sections...
writing nodes...
writing elements...
write geometry...
VERTEX SHADER INFO LOG:
FRAGMENT SHADER INFO LOG:
SHADER PROGRAM INFO LOG:
Serialization exception: Cannot open file: "C:/Users/medvi/Downloads/Wall_C2D_2 (1)/REC2.part-0.mpco.cdata".
class: HDF5
class: HDF5
class: HDF5
class: HDF5
class: HDF5
minor: Read failed
class: HDF5
File "C:/Users/medvi/Downloads/attachments (3)/Wall_C2D_SW.scd" succesfully loaded.
(document-wise)
Command: Regenerate
writing tcl input files in "C:/Users/medvi/Downloads/attachments (3)"
creating main script: "C:/Users/medvi/Downloads/attachments (3)\main.tcl" ...
writing sections...
writing nodes...
writing elements...
write geometry...
writing sections...
writing nodes...
writing elements...
write geometry...
Serialization exception: Cannot open file: "C:/Users/medvi/Downloads/attachments (3)/REC2.part-5.mpco.cdata".
class: HDF5
class: HDF5
class: HDF5
class: HDF5
class: HDF5
minor: Read failed
class: HDF5
AutoSave 1 (@ 1200000)
C:/Users/medvi/AppData/Local/ASDEA Software Technology/STKO\BackUp\Wall_C2D_SW-ae8cfd8c-9013-42ba-a3c4-ca22264fdf9b.bak
File succesfully saved as "C:/Users/medvi/AppData/Local/ASDEA Software Technology/STKO\BackUp\Wall_C2D_SW-ae8cfd8c-9013-42ba-a3c4-ca22264fdf9b.bak".
(document-wise)
Command: Regenerate
writing sections...
writing nodes...
writing elements...
write geometry...
File "C:/Users/medvi/OneDrive/Desktop/SKTO/exemples-webin/webinar_ssi_06_04_2020/single_processor/model_3d_init_stage_relax.scd" succesfully loaded.
(document-wise)
Command: Regenerate
writing sections...
writing nodes...
writing elements...
write geometry...
write geometry...
class: HDF5
class: HDF5
class: HDF5
class: HDF5
class: HDF5
minor: Read failed
class: HDF5
(document-wise)
Command: Regenerate
writing sections...
writing nodes...
writing elements...
write geometry...
class: HDF5
major: Symbol table
class: HDF5
class: HDF5
class: HDF5
major: Symbol table
class: HDF5
major: Symbol table
class: HDF5
major: Symbol table
class: HDF5
major: Symbol table
class: HDF5
major: Symbol table
class: HDF5
major: Symbol table
(document-wise)
Command: Regenerate
(document-wise)
Command: Regenerate
writing sections...
writing nodes...
writing elements...
write geometry...
write geometry...
Cannot open output database "C:/Users/medvi/OneDrive/Desktop/SKTO/documentation/webinaires/webinar_ssi_06_04_2020/single_processor/Nouveau dossier (2)/model_3d_init_stage_relax.mpco.cdata"
Error: cannot open "C:/Users/medvi/OneDrive/Desktop/SKTO/documentation/webinaires/webinar_ssi_06_04_2020/single_processor/Nouveau dossier (2)/model_3d_init_stage_relax.mpco.cdata".
Abort Command: OpenDatabase
Cannot create a plot without a Database
Abort Command: SurfaceColorMap
(document-wise)
Command: Regenerate
writing sections...
writing nodes...
writing elements...
write geometry...
write geometry...
class: HDF5
class: HDF5
class: HDF5
class: HDF5
class: HDF5
minor: Read failed
class: HDF5
(document-wise)
Command: Regenerate
writing sections...
writing nodes...
writing elements...
write geometry...
class: HDF5
major: Symbol table
class: HDF5
class: HDF5
class: HDF5
major: Symbol table
class: HDF5
major: Symbol table
class: HDF5
major: Symbol table
class: HDF5
major: Symbol table
class: HDF5
major: Symbol table
class: HDF5
major: Symbol table
(document-wise)
Command: Regenerate
(document-wise)
Command: Regenerate
writing sections...
writing nodes...
writing elements...
write geometry...
write geometry...
(document-wise)
Command: Regenerate
writing sections...
writing nodes...
writing elements...
write geometry...
class: HDF5
class: HDF5
class: HDF5
class: HDF5
class: HDF5
minor: Read failed
class: HDF5
(document-wise)
Command: Regenerate
writing sections...
writing nodes...
writing elements...
write geometry...
writing sections...
writing nodes...
writing elements...
write geometry...
class: HDF5
class: HDF5
class: HDF5
class: HDF5
class: HDF5
minor: Read failed
class: HDF5
(document-wise)
Command: Regenerate
writing sections...
writing nodes...
writing elements...
write geometry...
(document-wise)
Command: Regenerate
writing sections...
writing nodes...
writing elements...
write geometry...
write geometry...
class: HDF5
class: HDF5
class: HDF5
class: HDF5
class: HDF5
minor: Read failed
class: HDF5
(document-wise)
Command: Regenerate
writing sections...
writing nodes...
writing elements...
write geometry...
class: HDF5
major: Symbol table
class: HDF5
class: HDF5
class: HDF5
major: Symbol table
class: HDF5
major: Symbol table
class: HDF5
major: Symbol table
class: HDF5
major: Symbol table
class: HDF5
major: Symbol table
class: HDF5
major: Symbol table
(document-wise)
Command: Regenerate
(document-wise)
Command: Regenerate
writing sections...
writing nodes...
writing elements...
write geometry...
write geometry...
- Capture d’écran 2024-09-10 100355.png (77.95 KiB) Viewed 961 times
Re: try to run model of webinar_ssi_06_04_2020
The mpco.cdata is just a support file written by STKO for a better post processing.
But the real output database is the MPCO file, which is created by OpenSees if the analysis runs fine.
Why didn't you get the mpco output?
Did you use exactly the model from the webinar? Did you change something?
hello
i did use the original file acctually
it worked but in post processing i have only stage 1
Which one of the files?
Thera are many in that webinar
Hello
"For this step, I used model_3d_basic.scd. Then, I used model 3d init stage, but it doesn't create the MPCO file and gives me this message. Finally, I ran the last file, but it doesn't want to work." it says (multi_processor\test other>"C:\OpenSees-Solvers\openseesmp.bat" ".\main.tcl" 0 & pause
"RUNNING AS PARALLEL"
[mpiexec@BR_labtop] HYD_pmcd_pmi_alloc_pg_scratch (./pm/pmiserv/pmiserv_utils.c:595): assert (pg->pg_process_count * sizeof(struct HYD_pmcd_pmi_ecount)) failed
[mpiexec@BR_labtop] HYD_pmci_launch_procs (./pm/pmiserv/pmiserv_pmci.c:103): error allocating pg scratch space
[mpiexec@BR_labtop] main (./ui/mpich/mpiexec.c:401): process manager returned error launching processes
Appuyez sur une touche pour continuer...)
- image.png (154.04 KiB) Viewed 845 times
Hi, You can share the file (with the error) here, I will take a look at it.
here attached the files
Your zip and rar files contain six SCDs. Please let me know which SCD has the issue that you mentioned above.
Hello
you can choose one of them
just use rar or zip i put it two ways
thank you
thank you
as i mentioned
the basic model (model_3d_basic.scd) has only stage one and the other files as i described before model 3d init stage, but it doesn't create the MPCO file
