Hi STKO team.
When I was looking at the component stresses in the post-processing interface, I noticed that I couldn't select and display the related properties separately, which was not an issue before. What is the cause and how can I fix this?
Cannot choose properties in post processor
Re: Cannot choose properties in post processor
Hi, This is strange! It doesn't happen generally. It is challending to suggest anything with limited details. Have you loaded and kept the mpco database in a default settings?
Sorry, I don't get you. I haven't changed the settings of the MPCO database file.kesavapraba wrote: ↑Wed Sep 11, 2024 10:39 amHi, This is strange! It doesn't happen generally. It is challending to suggest anything with limited details. Have you loaded and kept the mpco database in a default settings?
Could you please tell me about how to check the settings of the mpco database?
Thanks a lot!
I meant keeping the mpco, mpco.cdata, and other supporting files in the same folder.
This happens when you don't have the mpco.cdata files next to the mpco files. Those are support files STKO uses to write extra information not available in OpenSees
