Truss results for frame building
KaushalPatel
Re: Truss results for frame building
Post by KaushalPatel » Mon May 20, 2024 8:57 am
Can you suggest me any uniaxial material model for FRP bars under monotonic loading? In the case of cyclic, hysteric model is good enough.
KaushalPatel
Post by KaushalPatel » Mon May 20, 2024 9:01 am
Can you suggest me any other material for model for FRP bars under monotonic loading? Because in cyclic loading, hysteretic model works pretty well.
I am not able to find proper material model for FRP under monotonic loading to capture its brittle behavior.
KaushalPatel
Post by KaushalPatel » Mon May 20, 2024 9:02 am
Post by STKO Team » Tue May 21, 2024 8:27 am
Use the materials -> uniaxial -> steel and reinf steel materials -> hysteretic.
It supports softening stiffness.
It's the multilinear that doesn't work
