recorder script for multi-analysis and globalForce
Lei Lei
Post by Lei Lei » Fri Mar 22, 2024 11:20 am
Dear STKOteam,
I would like to use a node recorder and an element recorder to output the desired results for a multiple-stage analysis.
However, it seems the results can only be recorded stage by stage with many files. Is there any way to output all stages' data into one file?
By the way, I tried to record a node's global force which a local axis is assigned to, but I filled. Do I only output local force when I set the local axis?
Lei Lei
Re: recorder command for multi-analysis and globalForce
Post by Lei Lei » Fri Mar 22, 2024 11:44 am
Lei Lei wrote: ↑
Ok, fine.
It seems just putting the node recorder command before the first analysis command makes sense.
Post by kesavapraba » Sat Mar 23, 2024 4:30 pm
MPCO recorder puts all stage results into its database (files can be one or many based on the partitions). You can extract all the stage results into a chart or as data using STKO post-processor
Global or local forces should be recorded for elements not for nodes.
Lei Lei
Post by Lei Lei » Mon Mar 25, 2024 6:16 am
Thanks for your reply!
kesavapraba wrote: ↑
I misdescribed it. It's for the element. So, do I only output local force when I set the local axis?
Post by kesavapraba » Mon Mar 25, 2024 6:26 am
Yes, you can see the results in local coordinate system only enabling localforce option in MPCO recorder.
Lei Lei
Post by Lei Lei » Mon Mar 25, 2024 6:44 am
Best wishes!
Post by kesavapraba » Mon Mar 25, 2024 6:52 am
You are welcome
