Push over error
sribeiro
Push over error
Post by sribeiro » Mon Sep 04, 2023 7:58 pm
I tried to run a push over analysis in the model below and it says it doesn't converge.
Previously I did a dynamic one and it was fine so I would like to ask for some help to understand what can be wrong with the pushover analysis.
Thank you in advance.
S
PSJ_v4.zip
(173.4 KiB) Downloaded 118 times
PSJ_pushover.zip
(184.01 KiB) Downloaded 154 times
Re: Push over error
Post by STKO Team » Fri Sep 08, 2023 10:45 am
The last geometry is a floating node, not attached to anything. Remove it.
Also, what is the "fix master" ? you don't need it because there you also have a rigidLink (it involves all 6 DOFs, it's not a diaphragm)
sribeiro
Re: Push over error
Post by sribeiro » Fri Sep 08, 2023 2:45 pm
Thank you very much!
It runs now :)
Re: Push over error
Post by STKO Team » Mon Sep 11, 2023 2:07 pm
