Two very similar models, why can't this one run.
[email protected]
Dear STKO team, please help me see why my model does not converge. I had a similar model before that worked fine.
- joint2 (2).rar
- (156.78 KiB) Downloaded 156 times
Re: Two very similar models, why can't this one run.
- Use GJ > 0 in Fiber sections
- Convert the rigidLink in either rigidLink(beam) if you want displacement-rotation coupling, or equalDOF(all dofs) if you want displacement-rotation un-coupled. For some reason the rigidlInk bar is not working
- Use the transformation handle in case of rigidLink(beam)
