MAXIMUM Time Step Calculation
FaizanAhmadNadeem
Hi STKO Team,
In the supporting excel file of 8th webinar, where 30Hz ricket wavelet was used as an excitation, the formulae used to determine maximum time step is { element size/sqrt(bed rock's shear wave velocity) }. But I didn't find any source, where I can logically see that how this formulae is correct.
Can you please guide me, how that formulae is derived?
Thank you, in Advance!
Re: MAXIMUM Time Step Calculation
It's called Courant-Friedrichs-Lewy (CFL) stability criterion.
However there is a mistake in the excel file. It should be mesh_size/shear_wave_velocity.
FaizanAhmadNadeem
Thank you for the response,
but why mesh_size/shear_wave_velocity?
why we are not using maximum wave velocity in the model, which is of course P-wave velocity, not shear wave's velocity?
CFL says, we should select a time interval in which, vibration information travels a distance less than the mesh size, and fastest moving information in FE model is P-wave! so, why we don't use P-wave? please correct me if i am wrong!
If you want to be sure, in the general case, yes, you should consider the P-Wave velocity as it's faster.
If I remember correctly, in that example, I was introducing only acceleration in X, which generates transverse motion (S-Waves). Of course, in the general case, P-Waves can also be generated as a result of complex interaction within the soil (different soil materials, interaction between waves, super-structure, etc..).
But that example was very simple, so to speed up calculation we only considered S-Waves.
Once again, it depends on the problem. Otherwise, if you want to be sure to pick a correct time step, use the fastest wave (P-Wave)
FaizanAhmadNadeem
Thank you so much for the clarification!
Can I have a suggestion from you?
Actually i am modelling soil vibrations induced by moving underground train. so, in my case, P-waves should be considered or it's not so much unrealistic to use maximum shear wave velocity instead of P-wave, to save computational cost?
what do you suggest?
Yes in your case, or in general for other generic source, I would use P-waves. At least you are sure not to make any mistake.
FaizanAhmadNadeem
Yes definitely.
Thank you so much for all the clarifications!
