1. I have finished compiling _HDF5.
2. Windows system runs normally, linux system program appears suspension, static changes to plastic when gravity balance (updateMaterialStage-material 7-stage 1)
3. Linux and Windows are compiled from source code, using the same code
4.I can provide linux system account and password if required
Error of MPCO recorder in linux
Re: Error of MPCO recorder in linux
- windows.zip
- (266.78 KiB) Downloaded 261 times
- linux.zip
- (260.94 KiB) Downloaded 248 times
- 20230228.png (175.81 KiB) Viewed 3074 times
1. Compile and install the source code provided by github to linux and windows.
2. The same code can run normally on windows, but on linux, the ground stress balance part, elastic to plastic (updateMaterialStage-material 1-Stage 1), the program hangs and cannot continue running. You can see the difference in the log file output0.
3. I tried linux on different computers and the same thing happened.
- windows.zip
- (266.78 KiB) Downloaded 262 times
- linux.zip
- (260.94 KiB) Downloaded 262 times
- 20230228.png (175.81 KiB) Viewed 3069 times
[quote=amb_1 post_id=6944 time=1677562882 user_id=3283]
It seems like a bug in the updateMaterialStage command, that for some reason can run on windows but crashes on linux. It will be very hard to detect.
Start by placing
Start by placing
command just before and after every "parameter" or "updateMaterialStage" commands. Also before and after each analysis. In this way you can try to localize the errorputs "some string"
Thanks, I'll try it
Let us know when the error happens, it will be easier for us to spot the bug
