which physical property is given for modelling a rubber material as cushion material in piled raft foundation.
Rubber material
Re: Rubber material
Rubber in general should be modelled with an Hyper-Elastic material if you want to analyze it under very large deformation.
But this is not the case.
I think cushion is used in composite pile-raft foundation just to redistribute the stress of the piles. So you can just use an Elastic Isotropic material
[email protected]
Re: Rubber material
Thankyou so much for the reply. One more query about the element property. Which element property is suitable for rubber material as cushion. I provide SSPbrick element is it ok.
Re: Rubber material
Any solid element is fine
[email protected]
Re: Rubber material
