I just started to study STKO with the e-Learning courses.
An error pops out when I run analysis with the ex4 in W3:
By removing the analysis steps, I believe the problem is in the 'load',
but I'm not sure what is the reason and how should I edit it.
Sincerely,
Uki
Problem in the ex4 of e-Learning
Re: Problem in the ex4 of e-Learning
The error is saying that you have a special character in your output directory.
Please don't use special characters in the files directories.
Thank you for the quick reply.
After changed encoding from Shift-JIS to utf-8 it works to me.
The analysis can run now.
Interesting thing is that before I practice with ex4,
I was practing with some simple examples and they didn't show the error message.
However, I still got some issue:
after: 10 iterations current Norm: 0.00122926 (max: 0.0001, Norm deltaR: 148973)
NewtonRaphson::solveCurrentStep() -the ConvergenceTest object failed in test()
I will try to fix by myself first.
Thank you again.
Thank you again.
Change the constraint handler from Penalty to Transformation.
Thank you for your prompt response.
Everything works fine now!
I appreciate it.
Sincerely,
Uki
I appreciate it.
Sincerely,
Uki
