Hello, how can I setup drift recorders in a multi-story building? Is it possible to do it only once so I can easily post-process drifts after each analysis?
Please let me know.
Drift recorders
Re: Drift recorders
Drift recorders in OpenSees can work only in sequential analysis. They do not work in parallel. (or at least they do not work in a straightforward manner).
We talked about this in out webinar on the Introduction to the STKO Python API.
One way is to use the Python API in STKO post processor:
Here you can find a building model for parallel analysis with OpenSeesMP. In the folder there is a python script for the STKO Python API to be used in the post-processor.
It will extract the drift ratio for all columns it finds. It will produce something like this: Another way is to add dummy zero length elements between the column-ends, add 2 dummy (E = 0) elastic material in the global X and Y direction. Record material.strain.
In zero-length elements it will be the displacement-jump.
You can then extract it from gauss-plot
Having a zero-length element between the 2 column's end-nodes will guarantee both nodes to be on the same processor.
Re: Drift recorders
Dear STKO Team,STKO Team wrote: ↑Mon Oct 10, 2022 8:05 amDrift recorders in OpenSees can work only in sequential analysis. They do not work in parallel. (or at least they do not work in a straightforward manner).
DRIFT.zip
I used this Python API in STKO post processor, and then attachment error occurred. What should I do to solve this problem
- erro.jpg (1.44 MiB) Viewed 4986 times
Re: Drift recorders
Sorry, my mistake.
Just remove utils. in front of ThreadUtils because you don't have it in a utils subfolder
