DamageTC3D in RC shear wall
[email protected]
I'm the first to attach the STKO software, before I study ABAQUS. I followed the teaching video about RC shear wall in Online Course Day 1 (https://asdeasoft.net/?university-courses) to establish the model. But the scd model files I established and downloaded on the webpage could not run successfully. If the DamageTC3D is wrong? I don't know the reason, I want to run an example model and learn how to establish.
The scd models files and running question picture are provided in attachment. The scd model file named by “wall-study-220310” is what I established, and the scd model file named by “wall-teach-220310” is download in the webpage.
Could you tell me the reason and how to solve the question? Thank you.
- 220312.zip
- (481.51 KiB) Downloaded 211 times
Re: DamageTC3D in RC shear wall
It's because it was done with a very old version of STKO, where we did not have an adaptive time step.
You can simply set the duration and number of increments (and the adaptive time step) directly in the analysis command, and get rid of the last custom command.
[email protected]
Thank you for your reply. But there are errors for the property.
If shoul I change the Plugin Library "pdm" in Opensees install file?
- 2022-03-15_100452.jpg (18.46 KiB) Viewed 3669 times
- 2022-03-15_082134.jpg (196.55 KiB) Viewed 3669 times
[email protected]
The concrete 1D property and 3D property were designed as
and
, but the error is as
At the same time, there are other running errors
, I don't know how to solve it.
Look forward to your reply.
and
.At the same time, there are other running errors
, I don't know how to solve it.Look forward to your reply.
- 2022-03-15_160058-2.jpg (38.66 KiB) Viewed 3665 times
- 2022-03-15_160058-1.jpg (40.78 KiB) Viewed 3665 times
- 2022-03-15_155705.jpg (53.78 KiB) Viewed 3665 times
- 2022-03-15_155643.jpg (42.25 KiB) Viewed 3665 times
Don't worry, those are not errors!
They are just messages to make sure that the plugin library (pdm) is correctly un-loaded (destroying library handle) and to count the number of materials used in the model.
[email protected]
Okay. However, the program stopped running. What should I do to finish the grogram and get the results?
The program did not stop running with an error. It's just finished correctly (ANALYSIS SUCCESFULLY FINISHED is a message that says that the analysis is done.)
Now, in that folder you should find a file with the *.MPCO extension. (if you used the MPCO Recorder command).
In the STKO post processor you simply need to load that file (Load DataBase command)
[email protected]
Sorry, maybe I'm not being clear. I do not get the results. Because, after I submit the model file, the progress ran a few senconds and then teminited. And the .mpco file is only 1.75 MB
, which is far samller than the size of .mpco file on the teaching vedio
I thinck that there is some wrong. Could you try to run the .scd file named by "wall-teach-220316" in the attachment? And you can find where the wrong is. Thank you.
.I thinck that there is some wrong. Could you try to run the .scd file named by "wall-teach-220316" in the attachment? And you can find where the wrong is. Thank you.
- 2022-03-16_205829.jpg (252 KiB) Viewed 3636 times
- 2022-03-16_210343.jpg (58.21 KiB) Viewed 3636 times
It's because in the horizontal analysis you set a duration = 0.
In this way, it was skipped.
Put 1 instead.
Put 1 instead.
[email protected]
Thank you. The model is successful.
I hope the scd model file should be update,. It can be helpful for new leaner.
The course is the online course day 1: RC shear wall.https://asdeasoft.net/?university-courses
The scd modle is in the attachment.
The SKTO is an excelent FE software. I hope more and moer people can use it and the software will be better.
