Load Database
Load Database
What is the difference between these 5 files? Which file should I import?
- 屏幕截图 2021-12-20 082216.png (46.58 KiB) Viewed 1220 times
Re: Load Database
They are simply 5 parts of the same output because you did a parallel analysis with 5 processors.
You can simply load one of them, and STKO will automatically open all of them as if they were a single file
