Pushover analysis error
Re: Pushover analysis error
Post by marafini.f » Wed Jul 28, 2021 8:48 am
See this other post
viewtopic.php?f=54&t=2008&p=3956#p3956
Please do not create numerous threads with the same topic.
felicegiordano95
Post by felicegiordano95 » Wed Aug 04, 2021 3:03 pm
Hello i can't see the tensions in the plates.
Esempio 3.6.rar
(566.62 KiB) Downloaded 182 times
Post by marafini.f » Thu Aug 05, 2021 4:21 pm
Dear felice,
Sorry we didn't get back to you about the stress in the plates.
You should try and use the layeredShell instead of the PlateFiber. You should define the material and then a LayeredShell physical property with at least three layers with specific thicknesses referencing that same material. The sum of the thickness is the total thickness of your slab.
Try it out and let me know how it goes.
felicegiordano95
Post by felicegiordano95 » Tue Aug 17, 2021 6:30 pm
I think I succeeded, in the attachment I insert the final file.
Esempio 3.7.rar
(570.91 KiB) Downloaded 181 times
Post by marafini.f » Mon Aug 23, 2021 2:23 pm
Dear felice,
I did not get what you want me to check.
I just ran the model and the period is very high, maybe you go the unit of the mass or the stiffness wrong?
Please analysis your results
Francesca :geek:
felicegiordano95
Post by felicegiordano95 » Tue Sep 07, 2021 10:07 am
Hello I wanted to ask you if the STKO software automatically calculates the g1, that is the weight of the elements, or should I also add this in the vertical loads.
Then I would like to ask if to increase the stiffness of the deck I have to insert a rigid diaphragm as a kinematic constraint, and where I could see a video that explains me how to do it ..
Thanks for your help.
Felice Giordano
Post by marafini.f » Tue Sep 07, 2021 1:09 pm
Dear Felice,
the software does not calculate self-weight by itself. You need to input it as a load.
As for rigidDiaphragms it is discussed in many videos, this for example.
https://www.youtube.com/watch?v=vPB9ZwTZbNw
felicegiordano95
Post by felicegiordano95 » Wed Sep 08, 2021 10:37 am
Even the mass does not calculate itself? and if so where should I insert it?
Post by marafini.f » Wed Sep 08, 2021 11:06 am
No it does not calculate itself. In conditions, you can add mass in the same way you add loads, at the nodes on the edges or distributed on faces.
If you type the word "mass" in the search bar of the forum you will find many threads on this topic that could be of use.
felicegiordano95
Post by felicegiordano95 » Wed Sep 08, 2021 4:09 pm
I can't reduce the period of this structure which should be around 1 and instead I get 10.
Esempio 4.4.rar
(580.88 KiB) Downloaded 161 times
