Dear STKO team
I'm working in SSI of a two storey building. I'm just studying the modal analysis, but when I run the model the structure doesn't stay attached at the soil.
what will be the problem?
SOIL STRUCTURE INTERACTION + MODAL ANALYSIS
- 06-DOS PISOS STKO(gravedad-SSI).rar
- (181.75 KiB) Downloaded 221 times
Re: SOIL STRUCTURE INTERACTION + MODAL ANALYSIS
Dear user,
There were 2 mistakes:
Here is the working file. Moreover, consider making the mesh finer. In your original file you used 1 subdivision per geometric entity. This is sometimes fine for beams/trusses (only when elastic, same section, etc...) but not for shells or solid elements.
- You have many overlapping constraints. In this case, the Transformation handler may not work. So you need the Penalty. In your case, 1.0e14 is a good penalty number.
However, in order to use the Penalty and not the default (transformation) for the Eigen, you need a "fake" analysis command just before the Eigen, where you set up the settings that you want. This "fake" analysis, should have NO STEPS (not a real analysis, just used to set up the "ingredients" for the Eigen command), and should not use the "wipeAnalysis", otherwise all those ingredients will be lost. - Your beam-to-solid interaction was wrong. It was connecting only 1 column to 1 foundation, and erroneously to a node from the soil. This interaction should use all the column-bottom-nodes as masters (retained nodes), and the top faces of the foundations as slaves (constrained nodes).
thanks for your advice, I really appreciate it.
I solve my problem. This forum is the best!!!!
Glad we could help and that you enjoy the forum! Goodl uck with your model
