ANalysis error
ANalysis error
I am receiving an error after analysis of FEM 2d model of RC beam-column assembly. Can U plz help. THe error and options selected for V & H analysis are shown below in screenshot.
- V analyss.png (22.82 KiB) Viewed 2625 times
- H anyss.png (20.65 KiB) Viewed 2625 times
- Error.png (61.62 KiB) Viewed 2625 times
Re: ANalysis error
It means that your model is singular, typically this means that it is not well constrained. But it's impossible to spot the issue without having a look at the file
Re: ANalysis error
Thanks for the response. The file is attached here for ur consideration.
- Realfonzo 2014, US, Ext.zip
- (116.52 KiB) Downloaded 209 times
Re: ANalysis error
Please follow these steps:
- Remove geometries that are not used (floating edges and vertices)
- Assign the Element Property (ShellDKGQ) to the geometry
- Reduce the time step or use the adaptive time step
