swap local axis
Jamildouier
swap local axis
Post by Jamildouier » Wed Apr 01, 2026 7:10 pm
Hello STKO Team,
In my model, some local axes are not aligned with the global axes. Is there a way or method to swap the local axes or change them so that they align with the global axes?
Thank you for your support.
Best regards.
Re: swap local axis
Post by STKO Team » Thu Apr 02, 2026 8:04 am
There are the commands to create Rectangular/Cylindrical/Spherical local axes. You can assign them to geometries to change their orientation.
Of course in beams they can change only Y-Z local axes (X is constrained to be the tangent to the curve), and in shells only X-Y axes (Z is constrained to be normal to the surface).
If instead you want to reverse the X in beams or Z in shells, use the reverse command
Jamildouier
Re: swap local axis
Post by Jamildouier » Sun Apr 05, 2026 12:41 pm
Thank you very much
Re: swap local axis
Post by STKO Team » Tue Apr 07, 2026 10:06 am
