I modeled a 50-story high-rise building with flexible slabs.
The model is fully linear elastic, using elastic beam-column and elastic membrane plate sections with ASDShellT3 elements for shearwalls and slabs.
I tested the model with mesh sizes of 0.5m, 1.0m and 2.0m using both MUMPS and UMFPack. With MUMPS, all mesh sizes ran successfully without errors. However, with UMFPack, only 2m mesh size completed. the 0.5 and 1m mesh sizes give following errors:
WARNING: numeric analysis returns -1 -- Umfpackgenlinsolver::solve
WARNING Linear::solveCurrentStep() - the LinearSOE failed in solve()
StaticAnalysis::analyze() - the Algorithm failed at step: 0 with domain at load factor 0.1
In another try, I divided the model into two sections, and ran each section independently with UMFPack, I could run it with mesh size 1m.
For the 1m mesh size, the model has:
Nodes: 141,329
Elements: 337,921
Questions:
1- Is this a known limitation of UMFPack for large models with high degrees of freedom, particularly those with flexible slabs?
2- Are there recommended methods or workflows for doing modal analysis on large buildings with flexible slabs at finer mesh size?
I appreciate your expertise and look forward to your recommendations.
Thank you for your time and assistance.
Hossein
