Analysis error: cannot find option attribute
Ostinelli
Post by Ostinelli » Mon Oct 27, 2025 10:05 pm
Hello.
I'm trying to do a simple plastic (fiber) analysis of a simple supported steel beam (IPE200), subjected to a uniform load.
But after the analysis, I select a NewtonWithLineSearch and toll=1e-07, there is this warning: cannot find option attribute..someone can help me please?
Thank you in advice
Re: Analysis error: cannot find option attribute
Post by STKO Team » Tue Oct 28, 2025 11:32 am
You cannot assign a Fiber or Elastic section directly to a Disp or Force BeamColumn element.
You first have to create a physical_property->special_purpose->BeamSectionProperty, where you choose the section and the integration scheme.
Then you assing this property to the beam
Ostinelli
Post by Ostinelli » Tue Oct 28, 2025 12:14 pm
Okay that's fine.
Now another error is shown...it's a problem of convergence..
Is there a lineguide to use resolution algorithms? It' a basic plastic analysis of a simple supported IPE200, subjected to an uniform distributed load..
Is it correct to select for this type of non-linearity a fiber section right?
Post by STKO Team » Wed Nov 05, 2025 11:45 am
We made many webinars about highly nonlinear models.
Yes
