Geometry limits exceeded
I face a problem, that is, when I save the model, and a window arises which shows that the limits exceeded. How to change the limit value, I am a beginner.
Re: Geometry limits exceeded
Hi, Do you work with limited/trial version of STKO? There is restriction on number of elements that you can use in limited trial version. Please check it.
