Pile lateral loading in SANISANDS
Posted: Thu Mar 26, 2026 6:04 pm
Dear stkoteam,
I am trying to model pile lateral loading using sanisand soil.
Both soil and pile are modelled as SPP brick elements. Pile material was set as elastic with the physical parameter of steel. pile inner diameter was connected to the central node at mudline through elastic beams, pile upper structure was modelled as Timoshenko beam and connected to the central node.
I found the shape of simulated pile lateral loading curve is different from that simulated in Plaxis (also the one calibrated for a centrifuge tests), which is quite similar to the problem raised in this post: viewtopic.php?t=3312&start=10
and the plastic effect of the sanisand model seems quite limit in opensees simulations.
I attach the scd files and some figures here, could you help to check if I implement some thing wrong in the model?/
