earth Stress
Posted: Wed Dec 10, 2025 1:42 pm
by MBR
hello,
I’m trying to extract the soil stresses so I can plot them, but I’m not able to.
Here is my model — it runs correctly, but I can only plot the displacements.
Re: earth Stress
Posted: Fri Dec 19, 2025 9:18 am
ask for material.stress and/or material.strain in the element results in the MPCO Recorder
Re: earth Stress
Posted: Wed Jan 14, 2026 9:38 pm
by MBR
Thank you for the reply .
Is it also possible to plot the stresses and/or strains in the same way as the displacements from the MPCO Recorder results?
Re: earth Stress
Posted: Mon Feb 09, 2026 8:50 am
Sure, stress (or any other result defined in Gauss Points) can be visualized:
- With gauss plot: In this case the result will be exactly the one on the gauss (integration) point as computed by OpenSees
- With surface color map: in this case the result will be extrapolated from gauss points to nodes
