Issue with MPCO file not being generated despite successful analysis
Posted: Wed Sep 03, 2025 11:42 am
Content:
I am sorry to bring up the same model issue again, but I would like to ask for your help once more.
Although the analysis finishes successfully (see attached CMD window output), the MPCO output file is not generated. I have checked the recorder definitions and execution path, but I still cannot figure out the cause.
To provide a complete picture, I am attaching:
The entire model files (compressed into a ZIP)
The CMD result window screenshot
The current RunSolver.bat command I am using
I would greatly appreciate it if you could kindly review these materials and let me know what might be the problem or if there is anything I should adjust in my setup.
Thank you again for your time and support.
Best regards,
Hongki
Content:
Best regards,
Hongki
