Tolerance & testCommand
Posted: Thu Jul 10, 2025 12:45 am
Dear STKO,
As part of my master's thesis, I would like to make a sensibility analysis about the analysis setup in a shear wall model. The main attributes that I want to evaluate are the testCommand and tolerance. The modifications that I would like to make are the following ones:
- testCommand: Norm Displacement Increment Test, Energy Increment Test, Relative Norm Displacement Increment Test, Relative Energy Increment Test.
-Tolerance: values of 10^(-5) , 10^(-4) , 5 * 10^(-3) , 10^(-2).
I will not prove Norm Unbalance testCommand because I am using penalty method constraint, so the convergency might be difficult. I would like to know your opinion about the matrix of testCommand and tolerance that I want to combinate; the values of tolerance that I chose are the default values in STKO and of other softwares like Diana and Abaqus. Also, I incorporated a value or 10^(-5) as a lower bound.
As I said, I would like to know your opinion based on your experience: what things could you suggest? is it a good matrix of combinations to prove?
Many thanks in advance!
