Analysis Error due to non convergence
My model, keeps getting analysis error, could you please help me on resolving this error.
- Tower Model.zip
- (273.45 KiB) Downloaded 96 times
Re: Analysis Error due to non convergence
Dear SRKO Team,
Your reply for this is highly valuable for my undergraduate research. Kindly help me to resolve this error. Thank you in advance.
Note:
Your model contains several disconnected geometries, such as floating nodes and floating edges. When two geometries are not physically connected, their corresponding meshes will also remain separated—even if their nodes appear to coincide in space.
To ensure proper interaction between parts, you should either:
- Merge the geometries to form a continuous mesh, or
- Define interactions (e.g., contact, tie constraints, or coupling) to specify how the separate geometries interact with each other.
