How to apply masses in a N-mm-s unit system - STKO
Posted: Tue Apr 08, 2025 6:00 pm
by bruznunez
Dear community,
I hope you are all doing well. I would like to ask about the correct way to apply masses to a structural plate system in STKO.
On one hand, I can input a RHO value within the material properties, but I have doubts regarding the units I should consider for this RHO. On the other hand, I know that I can also input masses using facemass. However, I have noticed a difference in the total mass of the system.
Why does this difference occur? What is the correct way to apply mass to plate elements?
Best regards.
Benjamin
Re: How to apply masses in a N-mm-s unit system - STKO
Posted: Wed Apr 23, 2025 4:11 pm
If you define the mass density in the materials (rho) then it should be a mass density (mass per unit volume).
If you use the FaceMass, it's a mass per unit area (i.e. rho * thickness of the shell).
Whatever you choose, make sure to be consistent with the units you are using!
Posted: Wed Jun 11, 2025 5:41 pm
by bruznunez
How it works the masstoLoad command in the analysis step?
Does exit any difference between use face masses and face loads in a TH analysis, considering the modal analysis step before the dynamic analysis?
Posted: Thu Jun 12, 2025 8:34 am
There is not masstoLoad command in STKO/OpenSees
A load is a load and a mass is a mass... you should apply both
Posted: Thu Jun 12, 2025 4:52 pm
by bruznunez
What about the load pattern named "massToLoad"? Maybe it's not a command but it does exist. How it works?
Posted: Mon Jul 07, 2025 8:19 am
It's an automation we make in STKO to simplify generation of mass and self weight for frame elements.
Problem:
In OpenSees, frame elements do not automatically get the mass density from the material. Therefore the user has to specify, for each element, the mass-per-unit-length (i.e. mass density * cross-section-area) either in the Element Property, or in the Mass->EdgeMass.
If you have a model with a lot of different cross sections, this can be tedious.
Solution:
We implemented a Condition->Mass->AutoEdgeMass, where you can specify the mass density (rho) and assign this condition to all frame elements with the same mass density. This automation will automatically process all elements and their cross-section to compute edge_mass = rho * section_area.
Optionally:
You can also check the "Convert to load" checkbox in the Condition->Mass->AutoEdgeMass, and add this in the load pattern under the option you mentioned
Posted: Wed Aug 20, 2025 10:49 pm
by bruznunez
See i was right
