Node can not be found due to partition
Posted: Fri Feb 07, 2025 10:49 am
by BuuNguyen
Hi STKO support,
I am modeling dynamic problem with tied boundary condition (nodes with same elevation share the same DOF).
However, I am using partition to run parallel, which results in an error of non-finding node.
For example, in the attached files, if I partition into 2 parts --> it run well, but 5 partition --> get error.
Can you have a look at my attached model and give me a solution?
Thank you for your support.
Buu
Re: Node can not be found due to partition
Posted: Mon Feb 10, 2025 9:52 am
We fixed this bug for the next version.
In the meantime replace this (unzip it) Python file in C:\Program FIles\STKO\external_solvers\opensees
mpc_solver_write_input.zip
(5.04 KiB) Downloaded 136 times
Posted: Mon Feb 10, 2025 2:48 pm
by BuuNguyen
It worked well. Thank you so much.
Buu
Posted: Wed Mar 12, 2025 1:25 pm
