Grouting sleeve model problem
Posted: Thu Dec 05, 2024 7:45 am
by haishui
Hi, everyone.
I'm trying to use STKO to simulate a pull-out test of a grouting sleeve, and I had built a simple model, but ran into some issues.
1. The following issue occurs when running,I don't actually know why this happen.
2.The model is mainly composed of a sleeve, grout and steel bars, of which the steel bars use fiber element, the grouting material uses solid element and the sleeve uses shell element, Is this setting reasonable?
3.How should I consider the bonding performance between the sleeve and the grouting material?
Re: Grouting sleeve model problem
Posted: Mon Dec 09, 2024 2:55 pm
Did you read the error message (the bold red one)?
Posted: Tue Dec 10, 2024 3:15 am
by haishui
yeah, I understand it literally,but I don't know how to fix it.
ok,I finally find out what's wrong, sorry for bothering.
Posted: Wed Dec 11, 2024 9:55 am
The element property requires an hexa mesh with 8 nodes, but you assigned this property to a mesh made with 27 nodes.
Just assign a mesh control to the solids set to Quad/Hexa - Structured - Linear
