How to create a local axis with an angle
Posted: Fri Nov 08, 2024 2:24 am
Hi STKO,
I am simulating a soil-pile interaction using py, tz, qz model. However, the piles are inclined with an angle of 20 deg with respect to vertical direction. Do you know how to create a local axis with an angle of 20 deg with respect to vertical direction? I can make a local axis with an angle, but I can not define a specific angle (20deg), as you can see in the attached figure.
Thank you for your support,
Buu
Buu
