pp visualization
Posted: Fri Sep 20, 2024 2:00 am
Good morning STKO team, I have a question regarding the pore pressure display in the post process tool.
To save the pore pressure results in U-P elements in OpenSees you must type vel or velocity in the recorder (https://opensees.berkeley.edu/wiki/inde ... UP_Element).
To get this value in the STKO post processor should I check the velocity or pressure box when creating the recorder?
Another question, when I select the option write input file all the commands appear in tcl except the recorders, where can I see the lines of code of the recorders of my model?
I wait for your answer, greetings.
