Extra dummy nodes
Posted: Wed Sep 04, 2024 9:29 am
by asherjackson
Dear Sir,
Can I define some extra nodes(not connecting any beams of columns) at floor level in order to find the Floor acceleration at that node point ?
Actually I need to find the Floor acceleration at Center of Rigidity. But the point where Centre of Rigidity is not lying at any node. Also, If I define any node at floor level, what should be the SP constraint there for that node ?
Thanks in advance.
Re: Extra dummy nodes
Posted: Wed Sep 04, 2024 10:54 am
by kesavapraba
Hi, You can use rigidlink with beam interaction (a multipoint constraint) to connect the node at CR with the node nearby.
Posted: Tue Sep 24, 2024 8:33 am
Use the ASDEmbeddedNodeElement. The rigid link will make the underlying element rigid, while the embedded element will not add any stiffness
Posted: Tue Sep 24, 2024 10:14 am
by kesavapraba
Agreed. Thank you.
