Drop down menù of the recorder items
Posted: Thu Jul 25, 2024 4:26 pm
by ludodam
Hi STKO team,
in the recorder I don't have the drop-down menu in any item, so I can't select the elements I need the results of.
I hope someone can help me asap,
Thank you so much!
Re: Drop down menù of the recorder items
Posted: Fri Jul 26, 2024 3:29 pm
Hi, Please share either scd or mpco files to debug the issue.
Posted: Sun Jul 28, 2024 9:27 am
by ludodam
Hi, yes sharing both.
Thank you!
Posted: Mon Jul 29, 2024 10:55 am
Hi, It seems from the attached figure that your database is corrupted - probably due to trying to stop the running analysis. Can you check the database that has results from the entire analysis or properly stopped analysis?
Posted: Tue Jul 30, 2024 9:49 am
What do you mean exactly? can you share a screenshot of that?
Posted: Sat Aug 03, 2024 11:08 am
by ludodam
Here I can't open it and select the elements
Posted: Sat Aug 03, 2024 11:19 am
by ludodam
Hi, sorry I sent you just a partition of the recorder, It's not corrupt. I'm trying to send you all of them but the file is too heavy I can't.
Posted: Mon Aug 05, 2024 8:53 am
If you can't select element and related info in the post processor it means that either you did not create the model in the STKO pre processor or you copies the MPCO files in a different location without the associated MPCO.CDATA files (those small files are required for those extra information)
Posted: Tue Aug 06, 2024 5:31 pm
by ludodam
I understand, so I don't have the associated mpco.cdata files between the analysis files but I didn't move anything. I've just ran the analysis and saved it in the same folder of the scd file. I created the model in STKO pre processor.
In the attachment the screenshot of the analysis files.
Posted: Thu Aug 08, 2024 7:38 am
OK, so probably you are running the analysis inside a folder where OpenSees and STKO have right to write, but not the python interpreter inside STKO (which is the one writing the MPCO.CDATA files).
What is the directory in which you are writing the tcl files?
Can you try to write the tcl files inside another directory?
