Hello STKO Team,
I am trying to model a Light timber frame wall but i am getting convergence issues due to interaction between shell and frame elements.
I am getting the following error
"ERROR: the analysis did not converge
while executing
"error "ERROR: the analysis did not converge""
I have attached the model for you review and would appreciate your response.
Interaction between the shell and elasticbeamcolumn element
- Model_Wall.zip
- (173.69 KiB) Downloaded 182 times
Re: Interaction between the shell and elasticbeamcolumn element
It's because the interaction between the shell and the frame is not complete.
If I understood correctly, you defined a Pinching4 material that should represent the shear behavior of nails.
If this is true, you assigned it to the 1st direction of the zero-length. But you have to ensure the interaction has proper local Axes: The first direction should be the tangential one!
By default, the 1st direction of the zero-length is equal to the global X-axis.
So you should define at least 2 interactions: The first for horizontal lines and the second for vertical lines.
Now you have to options:
- Define a single zeroLength material with the pinching in the 1st DOF. Define 2 local axes so that each interaction has the local X axis as the tangential one
- or, leave the default axis, and create 2 different zero length materials. The first one for the horizontal lines with the pinching in DOF 1, and the second for the vertical lines with the pinching in DOF 3.
