Virtual Hybrid Simulation
Posted: Fri May 31, 2024 11:36 am
by Jebran
I am trying to run a virtual Hybrid Simulation of a bridge using OpenSees and OpenFresco. I have connected a node of the beam ( beam is defined using elasticBeamColumn Element) with the top node of a column ( column is modeled using 3D fiber section). When I run the virtual Hybrid Simulation I I get the following error.
WARNING: CTestNormDispIncr::test() - failed to converge
after: 10 iterations current Norm: 0.000441142 (max: 1e-06, Norm deltaR: 6073.17)
NewtnRaphson::solveCurrentStep() -the ConvergenceTest object failed in test()
StaticAnalysis::analyze() - the Algorithm failed at iteration: 0 with domain at load factor 0.1
who to fix this issue?
Re: Virtual Hybrid Simulation
Posted: Mon Jun 03, 2024 7:48 am
It's a convergence problem.
You have to figure it out by yourself, there's not a unique solution.
Looking at the message you can get an idea:
Your model couldn't reach a tolerance on the displacement increment 1.0e-6 within 10 iterations (it only reached 4e-4).
Try to use more iterations, try a smaller time step, or understand why the residual error is so high (Norm deltaR: 6073.17, are you using too-stiff elements?)
