I am trying to apply the nDMaterial (ASDEASoftware / PlugIn) to simulate the masonry wall. Now, I am using the free unlimited 30-day trial of STKO, but when I perform the analysis, the following WARNING always occurs. Could you help me to fix it? Look forward for you reply.
Best regards!
Tao
nDmaterials - ASDEASoftware / PlugIn
[email protected]
- WARNING could not create nDMaterial: plugin
- 2.jpg (222.14 KiB) Viewed 1839 times
- nDMaterial (ASDEASoftware / PlugIn)
- 1.jpg (276.63 KiB) Viewed 1839 times
Re: nDmaterials - ASDEASoftware / PlugIn
It's because you are using the official OpenSees version.
In that version, the maintainer didn't want to add our plugin. So if you want the DamageTC3D, you must use the unofficial version distributed by Prof. Tarque here: https://www.pucp.edu.pe/profesor/sabino ... ducciones/,
otherwise you can use the ASDConcrete3D which instead is in the official version of OpenSees
[email protected]
Thank you very much! I have fixed the problem!
hi!
can you tell me how did you fixed it?
thanks
Download the un-official version compiled by prof. Tarque
https://www.researchgate.net/publicatio ... ltext=true
