recorder script for multi-analysis and globalForce
Posted: Fri Mar 22, 2024 11:20 am
by Lei Lei
Dear STKOteam,
I would like to use a node recorder and an element recorder to output the desired results for a multiple-stage analysis.
However, it seems the results can only be recorded stage by stage with many files. Is there any way to output all stages' data into one file?
By the way, I tried to record a node's global force which a local axis is assigned to, but I filled. Do I only output local force when I set the local axis?
Re: recorder command for multi-analysis and globalForce
Posted: Fri Mar 22, 2024 11:44 am
by Lei Lei
Lei Lei wrote: ↑Fri Mar 22, 2024 11:20 am
Ok, fine.
It seems just putting the node recorder command before the first analysis command makes sense.
Posted: Sat Mar 23, 2024 4:30 pm
MPCO recorder puts all stage results into its database (files can be one or many based on the partitions). You can extract all the stage results into a chart or as data using STKO post-processor
Global or local forces should be recorded for
elements not for nodes.
Posted: Mon Mar 25, 2024 6:16 am
by Lei Lei
Thanks for your reply!
kesavapraba wrote: ↑Sat Mar 23, 2024 4:30 pm
Global or local forces should be recorded for elements not for nodes
I misdescribed it. It's for the element. So, do I only output local force when I set the local axis?
Posted: Mon Mar 25, 2024 6:26 am
Yes, you can see the results in local coordinate system only enabling localforce option in MPCO recorder.
Posted: Mon Mar 25, 2024 6:44 am
by Lei Lei
Best wishes!
Posted: Mon Mar 25, 2024 6:52 am
You are welcome
