Adjusting transformation type with scripting
Posted: Fri Mar 08, 2024 8:54 am
by StavrosP
I cannot control the transformation type of an Elastic Timoshenko beam via Python.
So the following command highlighted in red doesn't return PDelta. Could you please guide me on how to get this?
xobj_el.getAttribute('transfType').String = 'PDelta'
def beam_element(i_beam, beam_w):
    Define the material per beam element.
    meta_el = doc_pre.metaDataElementProperty(
        'beam_column_elements.ElasticTimoshenkoBeam')
    xobj_el = MpcXObject.createInstanceOf(meta_el)
    xobj_el.getAttribute('-mass').boolean = True
    xobj_el.getAttribute('-cMass').boolean = True
    xobj_el.getAttribute('massDens').quantityScalar.value = beam_w
    # make the element
    prop_el = MpcElementProperty()
    prop_el.id = doc_pre.elementProperties.getlastkey(0) + 1
    prop_el.name = 'Beam_' + str(i_beam)
    prop_el.XObject = xobj_el
    # add it to the document
    doc_pre.addElementProperty(prop_el)
    doc_pre.commitChanges()
    doc_pre.dirty = True
    prop_el.commitXObjectChanges()
Stavros
Re: Adjusting transformation type with scripting
Posted: Fri Mar 15, 2024 1:47 pm
in line:
the .String property does not exits.
it is .string (without the capital S)
Posted: Thu Mar 21, 2024 10:06 am
by StavrosP
Thanks! On top of that in the command reported above I had a typo in the transfType. That should be transType. So:
xobj_el.getAttribute('transType').string = 'PDelta'
Posted: Sat Mar 23, 2024 3:49 pm
Glad that you fixed the issue.
