Outputs for damping forces
Posted: Thu Feb 22, 2024 5:53 pm
I'm trying to obtain in a concentrated plasticity model the damping forces aiming at obtaining the damping energy by integration of damping forces and nodal displacements. I've used the model for damping "modalDamping" and the recorders "rayleighForces" and "rayleighForces!". With the first recorder, I obtained damping force equal to 0 in all nodes in each step and, with the second recorder, I obtained a line of data for each mode that I understand that they are the forces obtained for each mode and node in each step.
Could I use the recorder “rayleighForces” in "modalDamping" or it is only valid for rayleigh command?
Could someone explain me how I can obtain the total damping energy dissipated by the model along an earthquake? I mean the outputs that I would need to compute it.
I really appreciate any comment
Best regards and thanks in advance
