Can not find "Model Stage 2 (PUSH)" in Post Processor
Posted: Sun Nov 05, 2023 8:41 am
I am new to STKO and OpenSees. I followed a tutorial on YouTube regarding RC Frame Structure by Asdea Software https://www.youtube.com/watch?v=vPB9ZwTZbNw .
In this webinar a custom command of adaptive time step was used. But since the version of STKO I am using has adaptive time stepping built in, so I used that open instead of the custom command. However when the Analysis finished I was not able to see model stage 2 which is related to "PUSH" in the post processor even though the all the analysis got completed when I did the analysis. After searching online about the issue I am across this post 2022 viewtopic.php?f=46&t=2198 .
In this post, an updated SCD file is provided. I downloaded it and compared that file with my own file and I tried to match almost all the things so that I can pin point exactly where I was making some mistake. However I was not able to figure out the mistake.
Another issue that I am facing is that while defining the analysis command for the vertical load, I can not find the option for "pFlag".
I have attached some screenshots highlighting my issues and I also attached my model file. Please help me in this regard as I am unable to find a solution
